need help asap! v70 wont fire up
Old Jan 4, 2017 | 01:20 PM
v70xcguy's Avatar
Default need help asap! v70 wont fire up
hell everyone.
my 2001 v70 xc. will not fire. the battery is good and the igniton works. I can here the starter turning over but and the car wants to turn over but the engine wont fire up. it almost fires up if I hold the gas to the floor but only then it sounds as if one piston is firing hardly. the engine will not run. as soon as I stop cranking the starter the car shuts off. first alarm I had on the dash was the immobilizer alarm. I don't have a remote entry key so I manually locked/unlocked the driver door five times and that alarm went away. I then attempted to start it and same thing happened only now it displays a "abs service required" alarm.
any help is greatly appreciated. really don't want to have to tow this one home.
thanks
Old Apr 5, 2017 | 11:14 AM
ArcticGhost's Avatar
First I would try to remove battery negative cable. let it sit for a while, maybe 5 mins, put it back and start it up...
Old Apr 5, 2017 | 05:43 PM
did you crank a long time to the point the starter slowed down? low battery voltage can trip some fault codes. cranking and "almost firing" sounds typical of a fuel pressure issue - fuel pump, relay, pressure sensor/pressure regulator.
Old Apr 5, 2017 | 06:38 PM
Smith Volvo's Avatar
Banned
I would smack the fuel tank with a 2x4 and that MIGHT wake up the fuel pump (nothing to loose)
waltonsauto
Feb 1, 2012 10:31 AM
waltonsauto
Jan 31, 2012 12:40 PM
djwhizkid
May 7, 2010 06:32 AM
Sanel30
Feb 18, 2010 09:16 PM
Dreas
Jan 23, 2009 09:32 PM
