New battery but dead?
Old Jul 20, 2013 | 06:32 AM
rowingman's Avatar
Default New battery but dead?
Put new battery in and car was fine for a while! Yesterday after about 2K the yellow triangle appeared so I drove home! In the driveway tried to start the car but battery was dead? Is the problem with the Alternator?
Old Jul 20, 2013 | 06:46 AM
Have it tested. Usually the dash warning lights will light up while driving if the alternator is bad.
If the alternator wasn't charging the battery the car wouldn't make it 100 miles. I have replaced 4 batteries in 1 car this year.
Post more details about your car and driving habits.
Old Jul 20, 2013 | 06:59 AM
Go to 4:15 on this video:
Old Jul 20, 2013 | 07:04 AM
rowingman's Avatar
Not used much but has been working well! Used car weekends and driven 50K and 70K without problems? Yesterday was particularly hot!!!
Old Jul 20, 2013 | 08:00 AM
Watch the video. It will explain that cars that are not driven much will drain the battery.
What year model is the car, how many miles does it have and what climate are you located? It does matter.
Old Jul 20, 2013 | 08:17 AM
rowingman's Avatar
2002V70 2.4T !!!! 174,000K !!!! Yesterday was brutal in Ontario, Canada, 40C+!!! Car started this morning but am getting it checked? Something is not right?
Old Jul 20, 2013 | 09:00 AM
There can be an issue with the battery cable. They build corrosion in the positive connector end. Your climate, age, and mileage is perfect for that condition.
Old Jul 20, 2013 | 09:54 AM
rowingman's Avatar
Connectors on battery are clean from corrosion!!!!
Old Jul 20, 2013 | 11:47 AM
ES6T's Avatar
If you put 4 batteries in a car in a year, I sure hope you checked draw.
You might have a current draw when the car is off. If the battery light isn't on, the alternator is charging in most cases.
timer00
Jun 6, 2012 03:04 AM
cmercon
Feb 2, 2009 02:15 AM
BigAdam
Aug 24, 2008 03:18 AM
festivus
Feb 10, 2007 10:01 AM
Darin
May 3, 2006 08:48 PM
