Dead battery then everything went wrong
Old May 2, 2006 | 06:09 PM
Darin's Avatar
Default Dead battery then everything went wrong
This morning I thought my 1999 S80 T6 had a dead battery. I jump started it and drove to work. On the way the car was acting real weird... the ABS sensor light came on and off (mostly on), then the airbag light came on and off, then the battery light was coming on and off and the radio would lose reception occasionally. Also, sometime the tachometer was staying at 0 and I had very little power. Then it would jump to normal and I had power. Finally, when I arrived at work 1/2 hour later and turned the car off, it would not start again.
SO weird. Any suggestions?
Old May 2, 2006 | 09:23 PM
Default RE: Dead battery then everything went wrong
Sounds like a Bad voltage regulator on the Alt.
Old May 3, 2006 | 11:12 AM
Darin's Avatar
Does that mean I should replace the Alt or can I just replace the voltage regulator?
Old May 3, 2006 | 08:48 PM
You can buy the Brush pack/Voltage regulator. I think it is like $130.00 or so compaired to $350.00 for the Alt.
tgrant
Jun 28, 2022 12:03 PM
MyVolvoV40
Feb 7, 2014 08:58 AM
koko284
Mar 15, 2012 05:30 AM
MC92
Feb 22, 2010 12:52 AM
J Telectro
Jan 10, 2007 09:25 AM
