Power Steering Flush
I am experiencing power steering pump noise. Noticeable at low RPM during parking. Fluid level is fine. The vehicle is my partner's and she had a local garage fill it. I suspect the wrong fluid was used. What is the proper procedure to flush out the system? Is there any seals I should replace while I'm doing this?
The easy way is to get a turkey baster and fix a short length (4-6 inches) of tubing to the end. Use the baster to suck the reservoir dry then refill with correct fluid. Start the car, turn lock to lock 3 or 4 times then stop - repeat this about 3-4 times and you should be about 90% new correct fluid. Should take about 1 quart or so. When in doubt, go OEM fluids - most euro frliendly web stores carry it as well as compatible brands.
tylerbarton
May 5, 2017 10:18 AM
rnsc
Nov 21, 2013 01:30 PM
