Is Power Steering damaged by non-Pentosin CHF 11S fluid?
Old Nov 20, 2013 | 09:45 PM
rnsc's Avatar
Default Is Power Steering damaged by non-Pentosin CHF 11S fluid?
A well meaning mechanic performing a safety inspection on my new-to-me 2005 S60 found that the power steering was almost empty and filled it up with a generic clear power steering fluid that he uses in everything and a little Lucas Power Steering Stop-Leak.
Is this OK, or should I flush it out and replace it with Pentosin CHF 11S? If I should change it, how urgent is it?
Thanks.
Old Nov 21, 2013 | 05:03 AM
John Arsenault's Avatar
Yes get it out of there!!! If you live anywhere near cold weather you will hear a god awful noise upon start up, it will sound like your PS pump is sucking air. Not sure about the seals and rubber but I would not take no chances.
Old Nov 21, 2013 | 06:23 AM
rnsc's Avatar
How do I get it out and fill it up? I assume there is a proceedure to get the system primed?
Any favorite sources for Pentosin CHF 11S?
Old Nov 21, 2013 | 01:30 PM
rnsc's Avatar
Perhaps I should note that he said that the stuff that was there was red. Also that he found no evidence of a leak anywhere.
dwhartwell
Apr 22, 2010 08:00 PM
dman777
Aug 22, 2009 12:18 AM
outdoor7or24
Sep 17, 2008 06:51 PM
Bruno937
Mar 22, 2008 09:55 AM
TranPlanner
Jan 14, 2008 05:16 AM
