Radio, Shifter Out and High Beams don't stay on
Hi,
2004 v70 ...Recently the high beams won't stay on lower cluster lights (odometer) ect. Shifter light is also out along with radio display, but radio works. Headlight switch is in the right position bout have to hold lever for high beams. Couple times after starting car everything work fine for a short period of time than back to problem. Replaced directional switch, didn't cure problem. Any ideas? Speedo, Tach, Temp, and Fuel gauges light, everything else no.
Thank You
Richard
Thank You
Richard
enjuaguese
01-01-2016 04:13 PM
