Rti not reading
Old Nov 19, 2019 | 11:11 AM
Bad hip's Avatar
Default Rti not reading
Hi I have a2008 v70 se with Rti. However it keeps coming up with an message stating the DVD Disc is not a Map, insert map DVD?
The disc is correct has any one any information on potential fix?
Thanks
Old Nov 30, 2019 | 05:40 AM
Older Now's Avatar
Surely someone out there must have some advice to offer? Here are some more details -
I have recently purchased a 2009 model year V70 2.5t se with RTI Sat Nav. However when I put the disc into the DVD player ( under floor in rear luggage area) the screen gives a message of either and or both “ cannot read disc and or Disc is not a map disc”. The disc is a Volvo one and correct for my model year.
Someone who is not a Volvo expert has recommended I run a cleaning lens disc through the DVD player. I have connected my local Volvo dealer who informed me that Volvo used to supply a cleaning disc but it is now obsolete and cannot help!
Can anyone recommend which type cleaning disc I could try (I see that you can purchase wet or dry type). Or know where I may find a Volvo cleaning disc.
I had also considered swapping the player for another second hand one, are these players mapped or married to each specific vehicle.
Any advice and guidance would be great.
Thanks
Old Dec 7, 2019 | 04:15 AM
Bad hip's Avatar
Ok I have tried a cleaning disc no luck, I have also checked the discs themselves and they look good. None of the three discs I have work all are original Volvo.
I have also found out that just prior to picking up my car it had a new cam belt fitted during which I would imagine the battery was disconnected.
Did I read somewhere that if the correct disconnect procedure was not followed then problems could occur? Is it possible that I have lost the DVD start up code?
I know a Tom Tom or similar is an easy alternative but I am keen to use the vehicles original equipment.
Any advice would be gratefully received.
Thanks
frenchyaz
Feb 22, 2018 03:40 PM
dery2013
Jul 22, 2013 09:44 PM
blackxc90innz
Feb 15, 2012 02:25 AM
PtolemaiosDante
Dec 17, 2010 12:06 AM
delfino26
Aug 7, 2005 09:00 PM
