V70 d5 2006 engine mount vacuum control.
Old Sep 1, 2021 | 08:20 AM
Bucks123's Avatar
Default V70 d5 2006 engine mount vacuum control.
Hi there.
I came Across a cheap v70 work horse that had a few issues to sort. So just working my way through them. Slightly stuck at the vacuum control valve that controls the engine mounts! I tested this with a vacuum tester and found it to be faulty. I replaced this but still is not allowing vacuum trough the valve! The pipe leading from the vacuum pump shows the correct pressure reading. Any tips would be much appreciated!! See below for said valve!
Cheers
Cwi.volvo.17
Jan 29, 2020 08:03 PM
Cezarila
Mar 15, 2018 07:46 AM
Czakky
Jan 1, 2016 12:21 PM
unbugai
Aug 6, 2010 07:39 AM
cool_kyle_3000
Oct 19, 2005 01:13 AM
