V70 - wont start - intermittent issue....
Old Jun 28, 2017 | 06:06 AM
Tony Hill's Avatar
Default V70 - wont start - intermittent issue....
OK - this is likely the MOST annoying issue I have ever experienced with a car..........
2003 V70 runs great BUT intermittently will not start - will turn over but nothing. As soon as you call the tow truck it starts.
Taken to TWO different Volvo dealers over the past two months and performed:
- starter replacement
- cam sensor, rpm sensor
- antenna light ring
for around 2K all in and this AM i would NOT START again.
I'm at the end of my rope - anyone have any good ideas?.....
Thanks in advace................
Old Jun 28, 2017 | 06:33 AM
pierremcalpine's Avatar
Does it start if you put the pedal to the floor when you turn it over? If so, take the idle control valve out and clean it with some brake cleaner and reinstall.
Old Jun 28, 2017 | 06:53 AM
Tony Hill's Avatar
no.... Tried:
- pedal to floor and various combinations
- taking out of park
- re-inserting key - BTW only one key left
ugh
Old Jun 28, 2017 | 07:47 AM
firebirdparts's Avatar
If that were me, seeing that I already spent $2000 I would get a VIDA DICE connection of some sort and experiment with it. This may not work, and you probably need to run windows 7, but there is a chance you can diagnose the real issue if you can make observations when it happens. I realize these are all knockoffs and so forth, but for $100 why not try it? there are some non-VIDA-DICE-clone options too (icarsoft makes one) that might work. You can see all this stuff on amazon.
Old Jun 28, 2017 | 08:06 AM
tryingbe's Avatar
Is there a fuel pump relay?
Old Jun 28, 2017 | 09:59 AM
Tony Hill's Avatar
bot sure
however when i came home from lunch the car starts perfectly
what is the issue:
- anti-theft device somehow ???
- surely someone else has seen this?...
Old Jun 29, 2017 | 05:53 AM
Search for faulty check valve in fuel pump...I seem to remember reading something about that recently. On a related note it may make sense for you to hook up a gauge to measure your fuel pressure at the rail. I'm not an expert here but thing to look for are low pressure or no pressure at start.
also, does your car have a fuel pressure regulator at the end of the fuel rail? When faulty it can cause mystery no start and stall conditions.
Old Jun 29, 2017 | 06:00 AM
Tony Hill's Avatar
id be a bit surprised if this were a fuel issue......
let the car sit for an hour come back starts perfectly......
seems like this is an electrical - perhaps anti theft circuit - issue.?....
Old Jun 12, 2018 | 10:42 AM
Tony Hill's Avatar
All
This turned out to be the fuel pump!!!
There is a shraeder valve on the fuel manifold making this easy to verify - fuel pump is a bear to change but.....
plog17
Oct 5, 2012 08:18 AM
major90
Sep 26, 2012 02:42 PM
pdlarson
Oct 25, 2011 11:36 AM
Nontechie
Oct 24, 2008 11:55 AM
crystalfleet
Jan 16, 2008 07:30 PM
