Windscreen Washer shenanigans
Old Feb 2, 2025 | 04:10 PM
Croggs3c's Avatar
Default Windscreen Washer shenanigans
Hi all. New here.
So, I have a weird issue with the washers on 09 plate V70. Basically, when both rear and front pipes are attached to the pump, as they should be, the washers do not work on either front or back. However, if only the front is attached, and the rear outlet on the pump is blocked up, then the front works fine. At first I suspected a pump issue, so it's a brand new pump on there, no issues there. Then maybe pipes are blocked, blew every line out with compressor and same with jets along with blasting water through them. Issue persists. Put the back pipe on front outlet, works fine, front pipe on front outlet, works fine, both pipes on, nothing. I'm at a complete loss. Current solution, I've blocked the rear pump outlet. Cut the pipe, put a T-piece in and attached rear pipe to that, which works fine. All be it with slightly lower water pressure.
Any Ideas?
Old Feb 2, 2025 | 04:22 PM
Originally Posted by Croggs3c
Hi all. New here.
The pump spins one way for the front and the opposite way for the rear to spray. Is that happening? (power is reversed on the wiring to make the pump spin backwards)
Old Feb 2, 2025 | 04:36 PM
Croggs3c's Avatar
Yep. When I had it out, had the intake in the bowl I used to catch the washer fluid to test the pump. Both front and rear work. Just, not when both pipes are attached.
GolAlex
Volvo C30
Jan 9, 2023 05:57 AM
VanaVolvo
Jun 15, 2018 08:50 AM
Phil 850
Nov 19, 2013 02:33 AM
teller
2001-2013 model year V70
Jun 2, 2013 07:24 PM
mason_200
Apr 18, 2007 08:21 PM
