'06 C70: Horn not working
Old Nov 7, 2014 | 11:26 AM
osage's Avatar
Default '06 C70: Horn not working
Local repair guy thinks we might need to replace the CRM (?)
I called the Volvo dealer: said there is no software module that drives the horn---it's either the horn itself or the contacts in the steering wheel.
I've gotta talk to the local guy, as he gave me a pretty hefty quote compared to what the dealer said it might cost.
Old Nov 7, 2014 | 01:26 PM
ES6T's Avatar
The CRM is the Convertible Roof Module. The horn has nothing to do with it and should be very easy to diagnose. Not sure I'd go to whoever you're going to anymore.
Old Nov 7, 2014 | 01:53 PM
osage's Avatar
Ooops...It's the 'CEM' not CRM.. Doug
Old Nov 7, 2014 | 01:56 PM
ES6T's Avatar
Okay, it could be the CEM. It grounds the relay that powers the horns when it gets signal to do so from the steering wheel module.
Old Nov 7, 2014 | 01:59 PM
osage's Avatar
hmmmm. Could it just be the 'relay' needs replacing?
BTW, and thanks so much for responding.
Old Nov 7, 2014 | 02:44 PM
ES6T's Avatar
It sure could. I would hope they diagnosed this properly before recommending something as costly as the CEM. If the relay has power and no ground when the horn is pressed, the signal to the CEM would need to be checked.
Old Nov 7, 2014 | 03:08 PM
osage's Avatar
Would the computer diagnostics show this problem?
Old Nov 7, 2014 | 05:03 PM
ES6T's Avatar
Depends what equipment they have. Not sure what kind of horn codes can be stored, if any. VIDA should be able to monitor the input to the SWM.
Old Nov 7, 2014 | 06:22 PM
osage's Avatar
Thanks!!!!
Rosy
Sep 11, 2010 08:45 AM
ROCNYS60
Oct 3, 2008 01:22 PM
mikeeyuk
May 1, 2006 08:40 PM
KESchumacher
Apr 18, 2006 08:33 PM
gur8
Aug 14, 2005 12:46 PM
