105K service & timing belt replacement, now oil leak; likely cause?
Old Jun 21, 2014 | 02:42 PM
David_Stack's Avatar
Default 105K service & timing belt replacement, now oil leak; likely cause?
Good Afternoon All;
Took our 2005 XC70 back to the dealer from whom we purchased the car (used), and who has performed nearly every factory service since new.
Had the 105K service performed, and the timing belt replaced (original).
Now the car is dripping motor oil from off the bottom of the A/C compressor housing. Looks dry around the crankshaft pulley...
Any suggestions on what they may have done to cause this problem? The car was leak-free up until now. I'll be on their doorstep first thing Monday morning, but would like to show up educated with what the root cause may be.
Thanks in advance,
Dave
Old Jun 22, 2014 | 02:04 PM
ES6T's Avatar
You sure it's oil and not power steering fluid? To do the belt, the power steering reservoir is moved out of the way. The clamp on the suction hose at the pump might need to be tightened. The hose is a common source of leaks anyway, even without disturbing it's position during other work.
Inga
Jan 26, 2012 01:46 PM
rodmodder
Nov 5, 2009 06:17 PM
nhpokey
Oct 1, 2009 05:05 PM
kriflic
Aug 11, 2009 12:57 PM
Svenz_v70xc
Mar 4, 2008 05:55 PM
