2009 XC70 Desiccant Bag Replacement
Old Jun 23, 2014 | 04:12 PM
tancookbelle's Avatar
Default 2009 XC70 Desiccant Bag Replacement
Purpose:
To show how to replace a desiccant bag which created a blockage in an AC system on a 2009 Volvo XC70. (This is applicable to many Volvos 2007+ and Landrover LR2
Background:
I have a 2009 XC70 3.2 with 196000 km. I went to use AC for first time since winter and it would not blow cool air. The compressor also made a whining noise when the clutch was engaged and the pitch changed with engine speed. I placed a gage on the LP side and found the pressure to be approximately 55 psi with the engine stopped. I started the engine and the compressor pull a vacuum on the system which indicated to me that there was a blockage. After looking at the AC circuit design I concluded that I had either a block thermal expansion valve or an exploded desiccant bag. I had the gas removed and the following describes the repair. It is noted that desiccant bag was only plugged and the fix was low cost.
Repair
First I needed to verify where the blockage was located. I removed both AC hoses at the compressor. I then opened the HP piping connection on passenger side in front of radiator expansion tank.
Using an air hose I blew air thru LP hose at compressor and air came out at HP pipe connection indicating thermal expansion valve was OK. I then blew air into HP hose at compressor and nothing came out at HP pipe connection, which indicated a blockage in the condenser. I first reconnected both compressor hoses and then the HP hose. I Googled desiccant bag failures and did not like what I saw. Failed bag with desiccant thru the system. This caused me to take the condenser out of car which in hindsight I did not need to do. Further on you will see I only needed to replace the bag.
I put the car up on ramps and removed the plastic panel in way of the oil pan. I then removed the plastic panel attached to the bumper (three plastic clips, 10 screws)
The last removal will be the four bolts for the metal cross-member that supports the radiator, condenser and oil cooler. Before you remove the bolts release the ¼” vent pipe from its bracket on passenger side of radiator. This pipe sees to much strain when you release the radiator support bracket.
At this point you should you removed the plastic plug (T-70 Torq) from the driver side of condenser which houses the desiccant bag. Below is a picture of the old and new bag and plug showing the blockage.
Install the new bag (3076238) and plug (30776239) and then reassemble everything.
Once everything is back together you will need to pull a vacuum on the system for an hour to remove any moisture in the systems. I purchased a vacuum pump that also came with AC gages (FJC KIT6 from Amazon).
At this point you are ready to recharge the systems with R-134A (0.8kg).
In my case I refilled the system with a product called R12A RedTek available in Canada at various repair locations. The two six ounce bottles and changing hose cost $58. My only problem was that I overcharge the system trying to install the 10.5 ounces of R12A recommended by the manufacture. The LP pressure went to 70 PSI and caused the compressor to make a very noticeable whining noise. Once I reduced the LP pressure to 30-38 psi; also a manufacture recommendation; the whining noise was gone and it was blowing cool air again (14C vent on a 28C day).
Summary
If your 2006+ Volvo AC system experiences no cooling, compressor whining and the LP side pulls a vacuum then you probably have a blocked desiccant bag. Have the gas removed in accordance with environmental regulation. You can probably do the repair yourself and then have the system recharged making cold air once again.
Attached Thumbnails 2009 XC70 Desiccant Bag Replacement-xc70-desiccant-bag1.jpg
rdp595
Jan 11, 2011 08:47 PM
lummert
Feb 9, 2008 10:00 PM
lummert
Feb 8, 2008 10:57 PM
STMullins
Dec 29, 2007 05:13 PM
