2004 XC70 Do I have 286 or 305 mm brakes ?
Old Dec 22, 2019 | 12:16 AM
shodanx's Avatar
Default 2004 XC70 Do I have 286 or 305 mm brakes ?
Hi,
It's extremely cold outside, I need to rebuild my front suspension. I've already got almost everything but the brakes.
They come in two sizes 286 and 305 mm.
My VIN is YV1SZ59H941140398
Searching online I can't get a straight answer, I even found a guy that asked the dealer and they got the wrong answer ?
I could go outside, remove the wheel and the rotor and measure it accurately, in the blinding cold, but I rather not if I can avoid it !
I suspect I have the cheaper brakes and that most of the 2004 xc70 have it, but I'm not 100% sure !
please help !
Old Dec 24, 2019 | 12:17 PM
what size wheels does your car use - if you have 15s then its the smaller size? I suspect the XCs use part # 31471830 which is the 286mm (11.25") model as I believe the 305s were for the R models. If you are concerned, remove the wheel and use this template tool: https://s3.amazonaws.com/fcp-pdf-files/rotor-tool.pdf
Old Jan 1, 2020 | 01:20 PM
shodanx's Avatar
I have 16 inch wheels, thank you for that PDF, we are having some warmer weather so I'll take the wheel off and check with that thanks !
Voldog
Sep 8, 2017 05:59 AM
Voldog
Sep 6, 2017 10:25 PM
dwenrhod
Mar 24, 2015 01:31 PM
samearle
Dec 27, 2010 11:26 AM
bigdog68
Oct 20, 2007 12:19 AM
