2005 XC70 Timming Belt
Old Apr 4, 2015 | 05:08 PM
Asamper's Avatar
Default 2005 XC70 Timming Belt
Hello all, I am hoping that I can get some guidance in preforming a timing belt change on my 2005 xc70. Now I have done timing belts in the past, however this will be my 1st time on this car. Any and all advice would be appreciated. Thank you.
Old Apr 8, 2015 | 04:23 PM
As with most cars, there are special tools required to hold the cam shafts in place and you need to get a lot of torque to crack the main pulley nut. Since these are double cam engines, there's a tool to lock both cams in place, then you can scribe the crank/pulley position to make sure the timing marks are hit. I assume you have a 5 cyl/twin cam? Look on Youtube - there should be some demo videos for V70/850s that should help.
Old Apr 8, 2015 | 05:00 PM
ES6T's Avatar
Locking the cams is not necessary for just replacing the belt.
Old Apr 9, 2015 | 08:08 AM
Asamper's Avatar
Thanks for the info!!!
mike_patrick
Oct 27, 2011 02:43 AM
Old Blue 66
Oct 13, 2009 04:22 PM
seattlego
Jun 6, 2009 05:30 PM
DontaviousJones
May 9, 2008 07:27 PM
nandrolone
Apr 4, 2008 07:14 AM
