Timming belt proceedure
Old May 8, 2008 | 08:44 PM
DontaviousJones's Avatar
Default Timming belt proceedure
Well I was going to take in our 2000 S70 N/A to have the timing belt, pulleys and water pump done, but I think I want to do it my self. From what I have seen the timing belt tensioner looks like a VW, I assume you use a hex tool to turn the tensioner eccentric till the tension arrow lines up and then tighten down, but I'd like to be sure. Is this how it is done? Does it have marks to line up the cam and crank pulleys? or are they in retarded places like on a VW. anything special about the crank bolt or crank pulley removal? Could anyone give me some quick tips? Im a pretty good mechanic, just need some instructions, or even illustrations would be wonderful!
Old May 9, 2008 | 06:56 AM
JimKW's Avatar
Default RE: Timming belt proceedure
I am pretty sure this covers the 2000 S70.
http://volvospeed.com/Repair/timingbelt.php
Old May 9, 2008 | 06:56 PM
Thanks for the informative link, but it shows the hydraulic tensioner and I have a mechanical, that looks very much like a VW tensioner.
Old May 9, 2008 | 07:27 PM
You bring it slightly past the window then brng it back some then tighten.
Also check out this link.
http://www.babcox.com/editorial/ic/ic60326.htm
peetcg
Apr 21, 2014 08:14 PM
beemerjunkie
Oct 28, 2010 01:20 PM
seattlego
Jun 6, 2009 05:30 PM
nandrolone
Apr 4, 2008 07:14 AM
hdbikedoc
Sep 27, 2007 09:25 PM
