2007 XC 70 Gear Shift stuck in park
Old Mar 10, 2018 | 08:16 AM
322hunter's Avatar
Default 2007 XC 70 Gear Shift stuck in park
2007 XC 70 Gear Shift stuck in park.
It happened once before and I took off the 2 side panels and sprayed it with an electric cleaner and it worked
No luck this time - I can't figure out how to get the plastic faux wood cover to lift off but a few inches - to get better access
Old Mar 10, 2018 | 04:48 PM
tony1963's Avatar
With a plastic trim tool, the wood cover will come up with a little effort. From there, you can manually move the lever to get it out of park. BTW, can you feel the solenoid move when you hit the brake?
Another problem might be the adjustment for the cable when you turn the key. I just fixed one of those.
2sailors
Jun 10, 2023 05:13 AM
Obelix
Jun 20, 2022 08:40 AM
Reis Cinnic O'Neill
Mar 11, 2018 06:55 PM
Kelly Caudle
Sep 28, 2017 08:27 AM
