2008 xc70 reduced engine performance
Hello,
I was driving yesterday and when I went to take off from a stop light the car stumbled and went in to a reduced engine performance condition. I was able to drive about 5 mph to a parking lot. From what I have read it’s most likely a throttle body issue. I removed and cleaned, but it did not resolve the issue. I changed plugs and MAF sensor. If I purchase a throttle body, would I need to have it reprogrammed? Can I purchase one ready to bolt in? Car ran great until then.
also, there has been a code for the evap being stuck open, but that been like that for a while.
thanks
thanks
Hello,
thanks
thanks
If I can remember the fuse had something to do With the throttle control module but honestly I would replace any fuses that mess with any electrical command units such as ecm and etc. wanted to clarify that it could be a BAD fuse not just a fuse.also you don’t need to reprogram your throttle body if the car is 2008 and older. I think but I have an 08 and I know for sure you don’t have to.
