Reduced Engine Performance Problem
Old Jan 9, 2020 | 04:20 AM
Kjack3410's Avatar
Default Reduced Engine Performance Problem
I recently had my 07' S80 3.2 die on the highway with the reduced engine performance warning. Tried to restart the car which it did but runs very rough and has no throttle response. I had the vehicle towed home where I scanned for trouble codes and came up with P1589. I searched the forum for any similar codes and have come up empty. Does anyone have any experience with the P1589 code and can point me in the right direction to getting this issue fixed before having to resort to the dealer? Any help will be greatly appreciated.
Old Jan 9, 2020 | 08:49 AM
that code is related to the throttle position sensor. Google "Volvo P1589" and you'll get plenty of hits.
Old Jan 9, 2020 | 10:07 AM
Kjack3410's Avatar
Yeah... That's what I turned up also but apparently it doesn't apply to this model as the sensor is all part of the throttle body which I replaced with no effect. Thanks for the info though.
Old Jan 9, 2020 | 01:02 PM
did you check with a dealer if any reprogramming is required for your replacement throttle body?
Old Jan 17, 2020 | 06:42 PM
Adrian Snare's Avatar
I have a very similar REP problem with the '03 S60, T5, AWD , 140K miles
REP = reduced engine performance .
A week has passed and ? .
I have read that throttle bodies are plug and play (newer ones)
And the throttle body may not be the problem .. there is also the plug in connections...corrosion problems ...
Do you pressure wash your engine as I do ? I have never had this problem with the Saab 900 ...luck or better design ?..
msl
Mar 21, 2015 04:26 PM
alpac
Dec 24, 2013 11:11 AM
jimcashin89
May 2, 2012 12:44 PM
diehardgator1
Feb 28, 2008 05:50 PM
jakson200369
Aug 14, 2005 01:10 PM
