S80 battery replacement leads to new air bag!
Old Dec 28, 2007 | 01:48 PM
STMullins's Avatar
Default S80 battery replacement leads to new air bag!
I have a 2000 S80 that needed a new battery. After it was replaced the SRS error light was on. I took it to the dealership and they accessed it and tried to reset it. However, they said there were TWO error codes in the computer. One for the battery reset and one for an error with the driver seat side air bag. They said this now needs to be replaced at a cost of $975. This all happened right after replacing the battery. Assuming I ever replace my battery again, is there anything I can do to protect against this happening?
Also, is this just a computer chip I can buy and replace myself?
Old Dec 28, 2007 | 02:01 PM
team's Avatar
Default RE: S80 battery replacement leads to new air bag!
just have them reset the codes and go from there. mine came on after a new battery, had them reset the code and all was fine.
Old Dec 28, 2007 | 06:37 PM
STMullins's Avatar
They did reset the code for the initial 'loss of communication' error, however the fault in the driver side air bag is real (and according to them, coincidental). I don't believe in coincidences and believe its related to the battery replacement. Can I replace this myself? Does anyone know where I can get service manuals?
Old Dec 28, 2007 | 07:07 PM
team's Avatar
have you had the latest software updates?
Old Dec 28, 2007 | 10:22 PM
I have changed hundreds of batterys in the S80's and never seen this before.
The code is listed as a permanent fault?
Old Dec 29, 2007 | 04:50 PM
STMullins's Avatar
What software are you referring to? If its the on board computer stuff, then I ASSUME so.
Old Dec 29, 2007 | 04:52 PM
STMullins's Avatar
They say its permanent.
Old Dec 29, 2007 | 05:13 PM
That is very weird.
rdp595
Jan 11, 2011 08:47 PM
lummert
Feb 9, 2008 10:00 PM
lummert
Feb 8, 2008 10:57 PM
PWHV07
Oct 4, 2007 12:15 AM
wufmama
Feb 20, 2006 11:44 PM
