2009 XC70 master window and mirror switch not working, door locks do work.
Old Apr 7, 2019 | 07:11 PM
jsmilde's Avatar
Default 2009 XC70 master window and mirror switch not working, door locks do work.
Hi all,
I have been searching the web but have not found a situation that matches mine. On the driver's door, none of the window switches work nor do the mirror controls. However, the locking switch is working fine. Anyone seen anything similar or have an idea what might cause that?
As a side note, I've seen mixed opinions about whether it is necessary to get a new switch programmed by the dealer. Anyone know if I can simply install a new switch or do I need to get it programmed?
Thanks
Old Apr 7, 2019 | 10:21 PM
ssicarman's Avatar
Check the body to door wiring harness for broken wires.
Old May 23, 2021 | 03:12 PM
SAMC51's Avatar
Default same issue
I have the same issue did you find the problem? can you fix it ? Thanks
Old May 27, 2021 | 01:10 PM
Mich's Avatar
Arrow Power Window Problem
I have the same problem but also the driver door lock doesn't work. All other windows and doors work fine except the driver's door. The information on the internet seems to indicate that my Driver's Door Module (DDM) is faulty. I have tried to find whether a used driver door module will work but the information is confusing. Some say you can replace your module with a used module and the programming will work if you find one with the correct numbers. My three numbers on the sticker of the module are: BP2THTVVB1, 0966017, 9401804. I can find 20 to 30 used modules with the 1st and 3rd number, but I can't find the 2nd number. I forgot to mention that my Volvo is a 2004 XC90.
joemcc
2001-2013 model year XC70
May 29, 2018 05:35 PM
sit987
2001-2013 model year V70
Jun 20, 2017 10:42 AM
glm409
Dec 22, 2014 08:55 AM
cshields
May 23, 2010 01:13 PM
