2012 XC70 - After engine shutoff, engine whines
Old May 2, 2024 | 10:12 AM
ChicagoAreaVolvoFam's Avatar
Question 2012 XC70 - After engine shutoff, engine whines
This is my first forum post - sorry in advance if I don't provide all necessary information, but I'll do my best.
I have a 2012 XC70. Base model, AWD, not T5.
Often, after I shut the car down, the engine will whine for a few minutes. It almost sounds like a very faint whine from the horn, but I cannot be sure of the source.
This has been going on for many months, and does not seem to be negatively impacting anything else. I even brought the car into the dealer to have a belt replaced, and they either ignored the issue or could not find the cause.
Any ideas what may be causing this?
Old May 20, 2024 | 12:01 PM
Fernando's Avatar
Hi
It may be the PCV trap clogged , after you stop the engine take out the engine oil dipstick, if the sound stop , it is the PCV clogged.
best Regards
Old May 21, 2024 | 02:52 PM
is the fan running? in warm weather the fan can run for a few minutes. have you opened the hood and looked around?
Old May 30, 2024 | 06:28 PM
Niklas11Braun's Avatar
It could be the power steering system. Sometimes, air trapped in the system can cause a whining noise after the engine is turned off. Also, check the transmission fluid level and condition.
If those don't seem to be the culprit, maybe inspect the alternator or even the cooling system.
Aussie Rob
Dec 3, 2022 09:35 AM
BjornVS
May 11, 2022 11:45 AM
Craig A Banikowski
Central
Dec 11, 2020 12:31 PM
thumperam
Aug 27, 2015 06:04 PM
lancer
Jul 12, 2011 04:48 PM
