2015 XC70 Suddenly Eating Oil
Old Oct 4, 2021 | 01:25 PM
gdstuart's Avatar
Question 2015 XC70 Suddenly Eating Oil
My 2015 XC70 T5 wagon has been trouble-free ever since I bought it but about 3 weeks ago I started to get a Low Oil warning. Adding oil sometimes satisfies it, but the warning keeps coming back on after 50-100 miles. Over this past 3 weeks I have added three qts of oil, and the system is still hungry for more. Dealer is mystified, wants to run a $700 Oil Consumption Test.
My garage floor is spotless and I see no smoke of any color so where's the oil going?
Thanks for any hints you might come up with.
Geoff
Old Oct 4, 2021 | 02:13 PM
Volvo was putting pistons rings in a certain model 5 cylinders for oil usage under warranty - does your engine fit in that time frame?
Old Oct 4, 2021 | 03:40 PM
I'd think that consuming 3 quarts in 100 miles would produce some smoke. Any other symptoms ie check engine light, sluggishness, rough idle? Oil's gotta be going somewhere and you're talking quarts in a few hundred miles - so I'm not sure why the dealer is mystified...
Did they explain what they are going to do in an "oil consumption test"? I'd expect a) compression/leak down test to check for rings b) look for oil/HCs in the coolant to check the headgasket (compression test may give clues here as well) c) oil in the exhaust (turbo seals) d) remove shrouds to look for leaks e) check color of plugs for fouling. f) inspect intake/MAF/ PCV oil separator.
Finally, have them measure the oil coming out of the pan. I'm assuming you don't have a dipstick, so it may be possible the oil level sensor is off and you've already overfilled the crankcase.
Old Oct 4, 2021 | 06:47 PM
gdstuart's Avatar
Any idea how I can find out about that program to see if I'm covered? Call Volvo USA? I was gonna do that tomorrow anyway.
Geoff
Old Oct 4, 2021 | 06:49 PM
ES6T's Avatar
You need piston rings.
Old Oct 4, 2021 | 06:50 PM
gdstuart's Avatar
Default Oil Consumption Test
Something about filling the oil, then driving until the light comes on, then weighing the remaining oil. Not nearly as scientific as what you suggested. I'm reluctant...
Geoff
SJManning
Apr 29, 2025 04:19 PM
lillite@sunlink.net
May 23, 2021 11:05 AM
zoesyd
Jun 24, 2019 09:48 AM
ggushee
2001-2013 model year XC70
Apr 29, 2018 09:04 AM
geordie
Aug 27, 2011 04:35 PM
