ABS and brake assist warning light and message
Old Apr 10, 2018 | 04:00 PM
Thang Vora's Avatar
Default ABS and brake assist warning light and message
My car 07 XC70; ABS and brake assist light and message need service on; Where should I check for the problems? Please help!
Old Apr 11, 2018 | 01:37 PM
tony1963's Avatar
You have to start with an appropriate scan tool.
Old May 9, 2018 | 02:44 PM
Matthew Halbert's Avatar
I had the same issue, out of nowhere. There was nothing wrong with the brakes so far as I (or my local volvo tech) could tell. I used the OBD2 scanner I purchased on amazon to clear the code to see if it would come back. Hasn't yet. There is a very specific scanner that you need for our (mine is an 04) xc70s. I can give you a link if interested.
Old May 16, 2018 | 07:19 PM
Thang Vora's Avatar
Thanks Matthew, please give me the link; The message would came on while driving, but after stop and engine turned off, when start and drive again the message dissapeared, it's drive me nut.
Old May 16, 2018 | 07:37 PM
Sure! The guys at the shop also said it could be a brake pedal sensor. Farther down the line they said I might need the ABS system rebuilt, but it works well for now.
iCarsoft Volvo/Saab Multi-system Scanner i906 Engine Vehicle Diagnostic Tool New https://www.amazon.com/dp/B06XVRDW4F/ref=cm_sw_r_cp_apip_f9aWJOQmLlwhO
Mike Bowen
Jun 23, 2021 11:54 AM
nealeas
Mar 24, 2018 09:59 AM
volvos80319
Jul 10, 2016 10:15 PM
phoffman
Aug 31, 2007 11:42 AM
