Safe to drive w ABS failure, acceleration slow
Old May 20, 2025 | 01:15 PM
ML1999's Avatar
Default Safe to drive w ABS failure, acceleration slow
Daily driver XC70 2004 here with 150,000 miles (I've had it one year). Recently had an intermittent "check engine" light move to ABS / Braking Failure (RED). It appears to be the ABS Module, but my mechanic anticipates a week turnaround w the holiday, and I need a vehicle. He says it should be safe to drive (??). Comments?
Question: acceleration w the error message from a dead stop is slow. I've read blurbs that this is normal, and I gather related to the ABS module. Beyond slow acceleration, are there any things to be wary of?
Thank you in advance.
Old May 26, 2025 | 05:42 AM
ccalberti's Avatar
Not that simple. The problem may be motherboard in the rear axle which controls the anti-lock brakes and a lot of other things (meaning you really need to replace it when it fails). These boards fail, even when nothing wrong t=with the ABS, and need to be replaced. There are only a couple of shops in the country who rebuild them, so you need to either order one and install it, of find a mechanic who understands older Volvos and will do this for you. I had this problem with my 2007 XC70 (180,000 at the time), had the board replaced by my mechanic in Annapolis, around $2200, vs local dealer asking $5000). There are a couple of discussions in this forum on this specific topic that you should search. Look at the websites for Midwest Modules and Module Master, the two shops I found that will rebuild your s or sell a rebuilt unit sources elsewhere.
Mike Bowen
Jun 23, 2021 11:54 AM
ABVO850
Aug 10, 2012 02:25 PM
98T5
Sep 3, 2009 09:08 PM
jweston5
May 14, 2009 08:21 PM
uncle
Jan 18, 2007 09:41 PM
