SRS Airbag Alert
Old Mar 28, 2018 | 05:15 PM
ultrarunner's Avatar
Default SRS Airbag Alert
I swapped out the small storage box with the OEM cup holder box today. This of course necessitated removal of radio and environmental heads. So, positioning the shift lever to drive makes this easier. With that said, the SRS alert came on at some point during this process, and now remains on. What is the best way to clear this message?
Thanks,
Ultra
Old Mar 29, 2018 | 01:25 AM
tony1963's Avatar
When you disconnect the climate control unit it interrupts the CAN BUS signal for the vehicle's interface between modules. The SRS Urgent appears in the window and can only be reset with an appropriate scan tool. An OBD II scan tool will typically not have the software to access the code.
You might be able to talk the dealer into doing the reset for free.
Old Mar 29, 2018 | 06:27 AM
Thanks Tony, very interesting. And I was thinking the 2014D OBD2 unit and computer would do a reset. Thanks for the heads-up.
Ultra
Old May 9, 2018 | 02:46 PM
Matthew Halbert's Avatar
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
This scanner will do it. Fixed mine when I had the same issue after replacing my radio.
Old May 11, 2018 | 01:49 AM
Yep, I got a similar one and reset the code. Thanks
atlantadriver
Apr 26, 2021 08:25 PM
kapka42
Jun 17, 2013 12:56 PM
Ferbis1021
Jun 8, 2010 03:50 PM
annemarie
Jan 11, 2010 07:54 AM
phantom309
Sep 7, 2006 11:38 AM
