'90 240 Check Engine Light and OBD
Old Apr 2, 2013 | 01:59 AM
240Wags's Avatar
Default '90 240 Check Engine Light and OBD
After firing up the motor this evening the check engine light remained on. After turning off the engine and putting the key to "on" position I checked the OBD. With the peg in slot #2 I pressed the button for 2 seconds. I received code 1-1-1. With the peg in slot #6 I received only continuous flashing. After 30 seconds of flashing without a code I closed the OBD. Any idea how to interpret or proceed? Thanks in advance.
Old Apr 11, 2013 | 12:07 PM
zjinqui1k's Avatar
If you post this question in the fourm under 240/740/940, you'll probably get a quicker response. I rarely leave that section, 'cause I don't know much about other Volvos.
From that forum area, under RWD FAQ's, the 7th post down gives this link:
http://www.troublecodes.net/Volvo/
But 1-1-1 means all clear. Not sure what to say when in peg 6... but if you ask over there, you'll probably get a better response.
rob17san
Nov 13, 2019 11:50 AM
sgvaibhav
Aug 25, 2014 05:13 PM
Krasniy Oktyabr
Jul 29, 2009 08:21 AM
rich nc
Jun 27, 2009 05:42 PM
ErnstlS90
Oct 23, 2008 08:37 AM
