940 SE Turbo steering noise
Old Apr 30, 2004 | 05:43 AM
adamjbarnes's Avatar
Default 940 SE Turbo steering noise
Silly problem which is probably easily repairable...</P>
When i'm driving, 90% of the time I experience a squeaky sound when i'm steering. Driving about 15mphthe noise isnot apparent, but at low speeds it's VERY annoying!!</P>
I've checked the power steering fluid level, which is fine, but fear it could be a problem with the power steering pump.</P>
ANY SUGGESTIONS?</P>
Cheers, Adam.</P>
Old Sep 3, 2004 | 03:58 PM
Wentworth Man's Avatar
Default RE: 940 SE Turbo steering noise
Adam,
Where is the squeaking coming from? Engine bay, inside the car itself, from the steering column or the steering wheel? Could be from any depending on the problem so depending on location it could be pump, rack, column bearing, airbag or electrical connector spring inside wheel. Equally it could be something as simple as the trim rubbing which could be solved with judicous use of PTFE tape.
Regards
Tony
gillings
Mar 20, 2011 07:27 PM
palebeachbum
Jan 7, 2011 10:58 AM
ogotaj
Mar 22, 2008 02:57 AM
intence
Mar 3, 2008 08:40 PM
katiejoyful
Dec 12, 2007 04:49 PM
