A/C in a 1985 240 DL
Old Jun 29, 2006 | 10:29 PM
brohism's Avatar
Default A/C in a 1985 240 DL
I have an '85 240 DL and I'm trying to fix the A/C in it. I bought a recharging kit, but it's for an R-134 type air conditioning system. What type of A/C system is in a 1985 240 DL?
Old Jun 29, 2006 | 11:42 PM
Default RE: A/C in a 1985 240 DL
Your 240 is R-12.
But can be converted to R-134.
You will have to drain the R-12 oil from the system and install Ester oil and add the R-134a fitting and recharge.
If you take it to a shop they will also want to replace the High side hose. It is a good idea but not a Must.
Old Jun 30, 2006 | 01:07 PM
brohism's Avatar
Ok, we'll see if I can do that. Might you off hand know of any good step-by-step instructions to do that? I'm not overly familiar, as you can tell, with my car's A/C system. I did discover yesterday that the nozzle on the end of the recharge kit hose does not fit the valve on the A/C system line. Can I get an adapter for that, or get a replacement valve?
Old Jul 1, 2006 | 09:44 AM
Check out this site and see if it helps you.
http://www.autoacsystems.com/
Somthngfrce
Jun 20, 2009 08:50 PM
barnesjonr
Apr 13, 2007 06:11 PM
swedeTbrick
Mar 28, 2007 08:55 PM
dsm2nr203
Dec 6, 2006 09:07 PM
1985_240DL
Sep 20, 2006 08:20 PM
