Sunroof won’t open
Old May 25, 2018 | 07:55 AM
pipo0509's Avatar
Default Sunroof won’t open
I have a 97 volvo 960
my sunroof won’t open any sugestión?
fuse are ok
appriaciate any help
thank you
Old Jun 10, 2018 | 12:23 PM
tony1963's Avatar
On the newer Volvo units, when the battery is dead in the alarm module, the sunroof locks out. Not sure if that would apply to a 97 model but at a minimum it is a lead for you to pursue.
Old Apr 2, 2019 | 09:30 PM
vasilert's Avatar
Default Need help-sunroof wont open when hot ok when cold
Hello everyone,
I have been reading about this issue what other people have. Mine is different.
When cold in the morning Sunroof and Map lights work, but when the car gets hot it does not.
The alarm works.when I press it on the remote.
Could someone give me some hints?
Thanks you in advance.
Old May 1, 2019 | 12:51 PM
sicnarf's Avatar
Heat causes the Wires to loose connection inside switch?
Old May 1, 2019 | 06:53 PM
+1 on heat causing a connector, switch or a relay causing a circuit to open up. You'd need to look at the wiring diagram or relay/fuse layout to see where the sunroof and map lights have common wiring/fuses/relays/ground points then test (a can of cold spray or compressed air can help by cooling off a component to see if the circuit closes as the device chills.)
e.mence440
Jun 14, 2018 08:53 AM
ultrarunner
2001-2013 model year XC70
Apr 29, 2018 09:17 AM
HeadDragon
Aug 19, 2012 10:39 PM
Deepesh
Jul 11, 2009 09:38 PM
backslide
Oct 21, 2006 04:14 PM
