Help.... My sunroof is stuck open!!!
Old May 25, 2018 | 04:25 PM
e.mence440's Avatar
Banned
Default Help.... My sunroof is stuck open!!!
Hello everyone,
Well I made the mistake of opening my sunroof ,
My alarm module is bad and I should've known better than to open the sunroof.
So, yes now the sunroof is open and won't go back down (it's in vent position) . Tried everything I think!
Any help with this matter would be greatly appreciated.
Old May 25, 2018 | 06:20 PM
tony1963's Avatar
I'm surprised that it worked at all with a bad alarm module. However, the only thing that I can think of is to disconnect the battery for 5 min and try again.
Old May 25, 2018 | 10:35 PM
e.mence440's Avatar
Banned
Default Sunroof finally went down
The sunroof finally went down. I tried everything that I was able to find , I was hoping that someone knew if there was a way to put it down manually .
I'm guessing that there isn't a way , but anyway like I said it finally went down.
The sunroof works from time to time , I should know better than to use the it but it was getting warm out and didn't want to use the a/c .
I will eventually pick up a used siren and try to get the alarm system working again , geez these cars can be touchy .
Old Jun 14, 2018 | 08:53 AM
jmoochie's Avatar
did you ever get this closed?
There should be a screw on the side of the little...regulator motor? Not sure what it's called. but it does have a little screw that is turnable.
pipo0509
May 1, 2019 06:53 PM
ultrarunner
2001-2013 model year XC70
Apr 29, 2018 09:17 AM
nicolaselias
Mar 21, 2011 04:32 PM
Stussy D
Dec 8, 2010 05:15 PM
Deepesh
Jul 11, 2009 09:38 PM
