Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
850 radio
Old Nov 30, 2007 | 07:58 PM
dsniner's Avatar
Default 850 radio
hello. i have a 96 850. 8 speakers and four outputs on the head unit. is there a amp some where down the line. is so, where. any wiring diagram would help.
thanks dave
Old Dec 1, 2007 | 08:19 AM
Default RE: 850 radio
If you have an amp there will be a Din plug plugged in on the back of the radio in the Amp hole.
Old Dec 1, 2007 | 09:16 AM
jks2's Avatar
Also, the Volvo amps are usually located underneat the seat.
Old Dec 1, 2007 | 09:56 AM
On the 850 the Amp is located behind the radio mounted to the bottom of the climate control box.
The amp is only located under the seats on the newer P2 platform cars.
Old Dec 1, 2007 | 01:04 PM
dsniner's Avatar
looked at the back of the stock head unit. nothing comming out of the amp din. the head unit has four outs. two left and two right. does this mean that the eight speakers are being fed by four outputs. if so then the power output would be cut in half. if there is a amp somewere then it would have to come off of the amp out, not a pre amp out. any ideas. thanks
Old Dec 1, 2007 | 01:36 PM
If nothing is plugged into the back of the radio in the amp spot you don't have an amp.
I believe the wires seperate and feed all speakers.
The factory amps aren't all they are cracked up to be.
Old Dec 1, 2007 | 01:51 PM
dsniner's Avatar
thanks
Old Dec 12, 2007 | 11:37 PM
Evo 850's Avatar
Factory amps never are. I even used a Jensen amp from eBay on my last beater and it sounded far better than the OEM!
cbgav
Sep 10, 2007 05:25 PM
Rand850
Jun 13, 2004 04:56 AM
Cyrusjj
Nov 15, 2003 06:33 PM
