Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Amp wiring help
Old Aug 15, 2008 | 07:07 PM
jaehok's Avatar
Default Amp wiring help
I am installing an amp and sub for my 2000 S80. Any one with the wiring diagrams?
Thanks,
Jae
Old Sep 11, 2008 | 01:59 PM
D_Jack's Avatar
Default RE: Amp wiring help
battery is in trunk... as well as rear deck speakers... run Line output converter off rear deck speakers , run power wire to battery, ground to solid piece of metal maby seat bolt... depending on amp some have remote turn on based on getting a signal.. if it does than you dont need a remote wire.. if you do need a remote wire in the left pannel of the trunk how you access the tail lights there is a fuse pannel find a fuse hot on the key and tap it... there you go..
emerlin
Jul 28, 2016 11:19 PM
aben132
Nov 12, 2014 10:03 AM
Echoe
Aug 26, 2009 12:08 PM
Echoe
Engine & Internal
Aug 20, 2009 12:07 AM
huzzsaba
Apr 2, 2009 05:35 PM
