Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
another radio code question
Old Jan 7, 2009 | 03:48 PM
luckofthedraw's Avatar
Default another radio code question
My car recently had the battery terminals cleaned, and of course the radio won't work. After searching here, I called the local dealer, and got the radio code. I have entered it several times, and it always came up with EEEE after I entered the code. After the last time I entered it, it says OFF. Guess I've maxed my chances out. So what do I do now? I did call the dealer back (prior to the OFF code coming up), and verifed that I had the correct code. Am I going to have to pull the radio out and get a code from the serial number? Please tell me no. I have never had much luck getting those little radio clip thingys back in.
Old Jan 7, 2009 | 04:30 PM
Default RE: another radio code question
What year and model?
To reset the radio you will need to leave the key in the first position for about 3 hours till it says code again.
Take the radio out and have them pull the numbers off of it.
Old Jan 8, 2009 | 07:41 PM
I had to try the key in first position for two 3-hour rounds, but it did reset.
The dealer needed both the serial number and the model number, but they did get me another/different code. And it worked! So after 3 weeks of no radio, it's finally working. Thanks for your help.
Old Jan 9, 2009 | 08:11 AM
Your welcome.
donf
Jul 4, 2012 08:47 PM
96960Chris
Jun 25, 2011 04:49 PM
nattyderek
May 10, 2010 09:04 AM
djbaines
Dec 31, 2006 11:48 PM
