Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
antenna on 1998 S70 needs replacement
Old Apr 6, 2012 | 02:41 PM
mulchie's Avatar
Default antenna on 1998 S70 needs replacement
I had a mast that got whacked in a car wash several years ago and my mechanic put in a new antenna and assembly at some ridiculous cost. Now the antenna suddenly won't come up. The motor spins, but nothing happens. I'm told new assemblies are $225 and salvage $75. This seems like a lot and we have 2 kids in college. Anything I can do to fix this without a whole motor replacement? I can hear it whirring, it is just that nothing happens!
I commute, and I need the news.
Old Sep 5, 2012 | 08:23 PM
Husker1's Avatar
Not sure if you ever got your answer, but I had something similar to another car I had. It could be that the antenna mast teeth is shredded or damaged and thus causing the whirring without the antenna ever reaching full mast.
You could replace the mast itself:
Power Antenna Mast for Sedans
Old Sep 5, 2012 | 08:49 PM
Yes, putting a new antenna in is easy. You can also add a switch to stop the motor from going up and down every time you start the car.
rspi
Jan 15, 2014 07:33 PM
modelageek
Sep 17, 2010 12:32 AM
bsobo
Apr 20, 2010 08:18 PM
trans am
Apr 16, 2009 09:17 PM
alecw81
Jan 7, 2009 05:22 PM
