Eclipse avn5435 Install?
S40 Test Fit
I test fitted the AVN5435 in the S40 today. The unit is a hair too wide. The OEM guide rails block it from sliding in. It also looks like there would be a 1/4 inch gap all the way around the unit head, requiring fabrication of a surround.
It appears the only kind of installation kit that would help is one that replaces the entire OEM radio housing. The kit would need to accomodate the Information ****, cup holder, and options switches located above the radio. I doubt such a thing exists.
The other option is to "modify" the existing enclosure. I think the guide rails could be shaved down enough to accept the radio without removing them completely. I am going to need them, since they help hold the radio in place.
I'll pick up a second OEM radio enclosure and try modifing it. I would like to preserve the OEM set-up so that the OEM radio can be re-installed.
I found this link for antenna and wire harness adapters, which I have ordered: http://www.myinstallkit.com/VOLVO/2002%20(02)%20VOLVO%20S40%20Radio%20-%20Stereo%20Installation%20Kit.htm
Adapters and 1-DIN installation kits are also available on eBay.
mordezmoncou
04-09-2007 03:01 PM
