Canada, Over Seas & Elsewhere Not from the states? Everywhere else post here.
Engine light is on constantly?
Old Jun 25, 2014 | 09:15 AM
rowingman's Avatar
Default Engine light is on constantly?
Is this a warning for a oxygen/or other sensor?
Old Jun 25, 2014 | 07:25 PM
difflock54's Avatar
Could be vast number of reasons for it.
Get your fault codes checked. That will give you a few leads to start from.
Old Jun 26, 2014 | 08:40 PM
pierremcalpine's Avatar
If you drop by your local Partsource they will happily loan you the code reader for a few minutes. At least mine here in Toronto does that as a free service. Just plug it in in the slot under the steering wheel and it will spit out a code. Then it's just a matter of a quick google search and you'll know what you are up against. Keep us posted.
Make sure you do follow up. It could be something small or it could be a warning for something bigger. Mine came on recently and I ignored it for a while. Turned out the rad fan was not working properly and I almost overheated.
crosby1
Dec 29, 2010 11:02 AM
luke8_8
Mar 28, 2009 02:27 PM
rgmendoza
Aug 28, 2008 10:46 PM
gagnecs
Jun 3, 2007 09:02 PM
ko_kidd
Aug 13, 2006 08:27 PM
