Detailing Discuss detailing your ride inside and out here.
Tired Paintwork on my 850SE
Old Dec 6, 2009 | 06:05 PM
SaintCam's Avatar
Default Tired Paintwork on my 850SE
Hey Guys,
I'm after some advice on restoring the tired white paintwork on my White '95 850 Wagon.
The paintwork is in pretty good condition, it's just looking faded.
I went into AutoPro the other day to see what they had in terms of waxes and polishes; and left empty handed, with the exception of a rather large headache. I just don't know where to start or what to use.
What should I do first? And what should I use?
I'm a big fan of a bit of elbow grease, and I don't own any electric polishing equipment.
I'd be forever grateful if someone could give me some step-by-step instructions... "You should start by doing xxx, and then xxx" etc.
The last thing I want to do is destroy my lovely new car!
Old Dec 6, 2009 | 09:35 PM
What I did on both of my cars was this.
We went to Walmart and got polishing compound. You put it on like wax and wipe it off using some good elbow grease. You should notice a difference right away. Then after doing the entire car we went over it with the Mothers cleaner wax liquid and it brought it back to looking like new.
Here is a post with pics of the wifes car from when I got it to after it was done. The entire steps are not in the post just pics of the overall progress.
https://volvoforums.com/forum/volvo-850-16/wifes-car-progression-upgrades-23504/
And some pics of mine.
https://volvoforums.com/forum/volvo-850-16/my-progression-upgrades-22381/
Old Dec 7, 2009 | 05:06 AM
SaintCam's Avatar
Wow! I can't believe how well the yellow came up! Nice work!
Pardon my ignorance, but is polishing compound like clay? Can you recommend a brand, or are they pretty much all the same?
Old Dec 7, 2009 | 07:38 AM
jks2's Avatar
Polishing compound is actually a very fine abrasive. It is actually removing the oxidized portion of the finish. Clay is not and is only designed to remove grit and grime that is setting on top of the finish. If your finish is gritty then you could clay first, followed by the compound . . . etc.
Old Dec 11, 2009 | 08:24 PM
Yes the compound is an abrasive. It comes in like a wax container.
Old Dec 13, 2009 | 04:39 PM
Lyonsroar's Avatar
I bought a cheapo Black and Decker random orbital buffer from Target ($30) and used the foam pad with ScratchX all over the entire car to remove oxidation, etc.
Here you can clearly see the 50/50 where I have buffed using the ScratchX and have not:
And the result:
Elbow grease can only get you so far. With my buffer I can wax the car in around an hour. After the ScratchX treatment I put Klasse All-in-One on, buffed it off, waited 24 hours, and applied 4 coats of Klasse Synthetic Sealant Glaze over 3 days. Expensive stuff, but the result is totally worth it.
Old Dec 13, 2009 | 06:31 PM
Somthngfrce's Avatar
Im a fan of using this stuff first to polish the paint with a buffer
the I use this stuff to seal the paint with a buffer.... You will think your paint is Glass!
Old Dec 13, 2009 | 07:47 PM
SaintCam's Avatar
I ended up buying this
And it came up really nice - so now I need some kind of sealer to finish it properly?
Old Dec 14, 2009 | 12:14 PM
This will seal that finish!
Old Dec 20, 2009 | 06:27 PM
Bobec's Avatar
This is what many professionals use
It comes in smaller bottles, just google. It's amazing stuff. You can use it with a buffer and don't have to worry about buffing through the paint..It's not a sealer. To wax/seal I'd recommend Eagle One Nano wax more amazing stuff.
Old Jul 10, 2010 | 02:48 PM
darkknight1999's Avatar
If you are still looking for step by step instructions I can write some up for you if you need them. I can also give you a list of product that can actually repair the paint and not just cover up the problem, so when you're done the paint will be both repaired and polished.
Its not that hard to do. I will cost a few hundred dollars to get the right items to properly complete the paint restoration though.
Just PM me if you're stilll looking for help.
mimi1
Apr 18, 2013 06:52 AM
jackotom
Aug 8, 2006 01:02 AM
hobbes921
Aug 29, 2005 01:50 PM
paul9619
Jun 10, 2005 10:46 PM
