Engine & Internal Chat about beefing up your insides here.
Quick E-fan questions
Old Jan 4, 2007 | 09:32 PM
laroqet's Avatar
Default Quick E-fan questions
I have a e-fan off a 89 dodge shadow i think will work just fine the wiring isnt the problem it is if i am to remove the belt running the OE fan as well i would think it would be running something internaly but im unaware.
Also what kind of gain would i be looking at after installing this.
Old Jan 4, 2007 | 09:42 PM
Default RE: Quick E-fan questions
You just remove the Fan and install bolts instead of the studs and keep the pulley on.
That pulley runs the water pump.
You may gain 2 HP.
Old Jan 4, 2007 | 11:16 PM
laroqet's Avatar
i guess that belt should stay there then!! thx for the help.
Old Jan 5, 2007 | 12:16 AM
No problem.
If you can post a pic of it once you completed the job.
Old Jan 5, 2007 | 02:48 PM
laroqet's Avatar
I record the whole process. Is it safe to do this before i get a safety/certified?
Old Jan 6, 2007 | 12:01 PM
If you do it nice and hide the wires and it looks good/safe it should not affect the safety inspection at all.
killarb634
Jun 8, 2008 06:59 AM
RadekTracz
Nov 19, 2007 06:04 PM
240beast
Apr 26, 2007 02:10 PM
losboricua
Jan 25, 2007 04:28 PM
t.d.
May 29, 2006 11:47 AM
