Engine & Internal Chat about beefing up your insides here.
Replace Int/Exh Valves
Old Nov 13, 2013 | 07:04 PM
nasko00v40's Avatar
Default Replace Int/Exh Valves
Hello fellow Volvo lover,
I need some advice. Here is a short story on what happened. had a exhaust cam gear seal leak, I bought a new cam gear with the seal. I used the tool to hold the cams in place. I did everything by the book, but I guess not cuz on my 5th try I lost compression. Skip forward I removed Head bend most valves and ding e piston tops see pictures.
[IMG][/IMG]
here is image of clean head
[IMG][/IMG]
[IMG][/IMG]
ADVICE 1--
I am looking for new Intake/Exhaust valves. Price from $8-64 /valve. which one to get? I cannot afford $64/valve but I need to know what is difference most of them say OEM or OES.
ADVICE 2--
See pictures of piston tops do i have to replace, I had a mechanic look at them and he said no problem i can use them but i would like 2nd opinion.
thank you
Attached Thumbnails Replace Int/Exh Valves-cam00185.jpg
Old Nov 13, 2013 | 09:24 PM
damien360's Avatar
i would replace the piston if it were my car. its better to be safe than sorry
Old Nov 13, 2013 | 09:37 PM
nasko00v40's Avatar
what about the valves? what is the difference?
Old Nov 29, 2013 | 10:15 PM
ES6T's Avatar
No need to replace the pistons. Just smooth out the edges around the indents so there are no hot spots developing.
johnnypaul657
Sep 16, 2010 01:01 AM
dgm76513
Oct 11, 2008 08:47 AM
HenrikS40
Dec 23, 2007 04:42 AM
brax
Sep 28, 2006 11:23 PM
itsagirl
Jan 29, 2006 06:36 PM
