Engine & Internal Chat about beefing up your insides here.
Volvo 850glt 1996
Old Jun 6, 2011 | 03:33 PM
anthony reddy's Avatar
Unhappy Volvo 850glt 1996
Hi on a 850glt Volvo auto -engine has hard starting -got to crank it for a while and if it starts -its got a retarded rev and misses and wants to cut off up to about 3000rpm - if its revved over 3000rpm its fine -but when u leave the accelerator pedal it cuts out -done compression test all cyl.
Above 1200kpa. -checked plug gap and ht. leads all okay also firing -even fed direct power to fuel pump ,still hard start -i was told if it starts and runs fault won't be cam and crank sensor---could fault be mass air flow sensor or what ?
Need ur help and advice
Old Jun 6, 2011 | 03:37 PM
On volvo 850 glt auto --i was towing a bakkie in reeverse out of my yard for a short distance like 40m didnt make any noise ar any thing just packed up and eventually i cannot get reverse gear -all forward gears are fine -what would cause this
Old Jul 28, 2013 | 02:13 PM
Rosew6211's Avatar
My code reader showed mass air filter problem which I confirmed by disconnecting it. Apparently this places system in limp mode and engine will run ok. Got another MAF unit on e-bay, installed it and problem solved.
Old Oct 17, 2013 | 07:24 PM
FASTER's Avatar
My 850 did exactly that, turned out was the cam sensor. After replaced it fired right up.
As for the tranny issue I haven't a clue
Old Nov 1, 2013 | 11:43 PM
jose456891's Avatar
First things first:
You have a 96 model, that means that your car has a OBDII port. I suggest that you borrow a code reader and post the results here.
2nd: I'm assuming that you have the FWD version. That means that to tow the car with the from wheels on the ground the tranny has to be in N and not exceed above 30mph. Since you towed it while the tranny was in Reverse I'm afraid that you might have broken something.
I lost reverse on my 850 when I accidentally cut a wire that controls solenoid A in the transmission. If you had your car sitting for a while in your yard, maybe mice/rats chewed on the harness. This is common! This is not hard/expensive to fix, but its time consuming.
For the hard start, it is something either in the fuel or air system. I suggest that you pressure test the fuel stem and look for air leaks in the vacuum lines and after the MAF. I fixed intermittent shutdowns in my 850 after replacing the fuel filter and the fuel pump relay.
Get those engine codes read ASAP!
Old Dec 11, 2013 | 04:32 AM
GlendaAlvarez's Avatar
OK .. i got it .. then this way it is going to happen i was not aware with but now more clear with the issue to do it with due safety
Tevida Side Effects
David
Jul 28, 2013 02:28 PM
mooses9
Feb 27, 2010 10:01 PM
Dads850
Aug 1, 2008 02:21 PM
silentdeath489
Apr 18, 2007 09:53 AM
jakes850glt
Apr 9, 2007 10:54 PM
