Engine & Internal Chat about beefing up your insides here.
WHAT BOV TO GET?
Old Jul 18, 2007 | 06:40 PM
  #41
olegs70glt's Avatar
Default RE: WHAT BOV TO GET?
when i floor it, goes up to only 7 or like 7.5 - 8 psi, but its a 15g turbo.
Old Jul 18, 2007 | 06:46 PM
  #42
S70driver's Avatar
Ok good I wanted to be sure you weren't over boosting.
Old Jul 18, 2007 | 07:16 PM
  #43
olegs70glt's Avatar
ORIGINAL: S70driver
this 15 G turbocharger I have, gives boost like its a13G, you know why? it gives 5-7 psi, same as ifI would 13G
1. ecu is from old engine that used to have 13G turbo?
2. guage is not accurate, but its unlikely.
Old Jul 18, 2007 | 10:23 PM
  #44
S70driver's Avatar
ORIGINAL: olegs70glt
ORIGINAL: S70driver
Are you sure it is a 15g? What car do you have again?
1. Could be but highly doubt it.
2. I doubt it is the gauge.
Old Jul 19, 2007 | 02:06 AM
  #45
olegs70glt's Avatar
Hi, I have 1998 Volvo s70 GLT, but I have 2.3 Liter enginewith 15G TurboCharger, dont know from what year, but 99% sure from 850 t5, because 850T5 is the only one that had 2.3 with 15G
Old Jul 19, 2007 | 02:07 AM
  #46
olegs70glt's Avatar
100% Sure it's 15G My father is mechanic, we took it out and put newer one in it. it said on the label 15g
Old Jul 19, 2007 | 11:09 AM
  #47
S70driver's Avatar
Ok my next question is this. Are you running an HPT turbo on an LPT engine?
I do believe I answered this question above myself. Just from your forum name olegs70glt. Yes you are an LPT engine and you put an HPT turbo on your car.
By putting an HPT turbo on your car your not going to be running higher boost then what your engine is set for. You either have to buy a manual boost controller and control your boost this way and or get an ECU upgrade from the various vendors available for Volvo's.
Old Jul 20, 2007 | 12:21 AM
  #48
olegs70glt's Avatar
ORIGINAL: S70driver
Hey, no the whole engine including the turbo is from different car,pretty sure its from 850, my father told me it's a 2.3L and it has 15G turbo.
Old Jul 23, 2007 | 04:21 PM
  #49
olegs70glt's Avatar
By the way, I found out what was wrong with the boost guage, the vacuum hose that came with the guage was too thin and it got crushed in the pillar, so I had to replace it with better thicker hose. Now it works amazing.
Old Jul 23, 2007 | 04:28 PM
  #50
S70driver's Avatar
That is good.
Old Aug 28, 2007 | 10:03 PM
  #51
805c70's Avatar
hey what do you guys think of the Greddy Type S BOV? like compared to the HKS SSQV BOV which one would you pick?
Old Aug 29, 2007 | 07:02 AM
  #52
S70driver's Avatar
ORIGINAL: 805c70
HKS SSQV hands down one of the best BOV's on the market besides TIAL.
Old Dec 12, 2007 | 09:43 AM
  #53
olegs70glt's Avatar
S70Driver, you said I can control boost with manual boost controller, electronic one like greddy won't do it?
thanks,
Oleg
Old Dec 12, 2007 | 11:06 AM
  #54
S70driver's Avatar
thanks,
Oleg
Sorry your going to have to quote me. I am not going to go back in the pages to find what I said.
Anyways. If your car is 1998 and before you can use a manual boost controller (MBC) or you can use a Electronic Boost Controller (EBC).
However 1999+ Volvo's use what is called ME7 and ME7 doesn't like it when you use a MBC. I don't know about an EBC but MBC's it hates. So don't use one if your 1999+. Now you can use an ECU upgrade on the 1999+ models to raise boost levels.
Old Dec 12, 2007 | 04:39 PM
  #55
Lab_Rodent's Avatar
Your ME7 is what I think others call a TCV. You have to bypass it to us an MBC/EBC. It basicly is an EBC valve controlled by the ECU.
Old Dec 13, 2007 | 08:25 AM
  #56
S70driver's Avatar
ORIGINAL: Lab_Rodent
http://www.wothrline.com/Cars_engine.../M7x_index.htm
"The biggest difference between the ME-systems and the older M4.x systems is the new throttle module, a so called fly-by-wire system where there’s no wire between the throttle plate and the accelerator pedal. Throttle plate is controlled by an electrical motor via the ETM and signals from the accelerator pedal positions sensor. VVT-system is also new and for MY99-01 all turbo engines had exhaust VVT. 2.5T, 24HT and R-line engines have VVT on both inlet- and outlet cam shafts."
Old Dec 30, 2008 | 02:51 PM
  #57
linken's Avatar
I see, what else do you reccomend except hks ssqv, the problem with it is that it makes whistling sound, I like pshh, more like turbo XS makes? any ideas?
hks sells 2 different inserts for the ssq. a gold one and a purple one. you tube it i forgot which one has less of a whistle. they show it on a srt-4 but youll get the idea.
Old Jan 13, 2009 | 08:20 PM
  #58
firechicken99's Avatar
how hard is the install on the BOV's?? where could i find the proper flangers?? this is my first time working with a FI car any chance someone knows of a page with a BOV how to??
Old Jan 14, 2009 | 01:31 PM
  #59
S70driver's Avatar
fire what car do you have?
Old Jan 15, 2009 | 12:26 AM
  #60
2004 S40 T5 FWD AUTOMATIC (wish i knew the damn automatic part made a difference when buying rotors a few months ago lmao)
chs68
15
Apr 25, 2006 12:48 PM
kaz
Feb 16, 2005 05:53 PM
cecilvaliant
Jan 27, 2004 04:41 PM
soslow93
Dec 11, 2003 07:14 AM
