01 Volvo V70xc Steering Problem
Old Nov 27, 2008 | 09:42 PM
ruazor's Avatar
Default 01 Volvo V70xc Steering Problem
I have a 2001 Volvo v70xc, I had a Problem with the steering, when I turn to right or to the left, the steering gets heavy and soft, goes like bumping when you turn to any side. My mechanic told me was the steering rack, was replaced for a used one, then after still the same, he replace the steering pump, still the same, What it should be? I heard, these cars have a electric power steering and a steering column control module, it should be something like this or something else? Thanks
Old Nov 28, 2008 | 09:33 AM
Default RE: 01 Volvo V70xc Steering Problem
Check the power steering fluid bottle.
Old Nov 28, 2008 | 09:15 PM
ruazor's Avatar
What do you think?
Its something in the Power steering oil bottle . Actually after he replace the pump, the wheel was working well but just for a short period of time then a few hours after start doing the same, it needs a flush on the system, do you think that will help?
Thanks anyway for your help.
Old Nov 28, 2008 | 09:25 PM
When driving does it make noise almost like it is low on fluid?
Old Nov 29, 2008 | 11:45 PM
ruazor's Avatar
No..It just keeps heavy and soft when you turn to either side. Like bumping the wheel not smooth as supose to be.
Old Nov 30, 2008 | 07:22 AM
Sounds almost like the used rack is bad.
Deke MacPherson
1998-2000 model year XC70
Oct 27, 2012 02:06 AM
castrex
Nov 12, 2009 06:40 PM
jklenk
Aug 18, 2008 12:26 AM
