1988 Transmission Overdrive Switch
Old Feb 15, 2007 | 02:37 PM
Dennis1's Avatar
Default 1988 Transmission Overdrive Switch
My overdrive switch activatedit's self on my 1988 240DL. Where is the switch and/or solenoid located? Is there more than one item that may need to be replaced? Any special tools or trickes in replacing these parts?
thanks
Old Feb 15, 2007 | 02:44 PM
volvo4mula's Avatar
Default RE: 1988 Transmission Overdrive Switch
The solenoid is on the left side of the tranny above the pan. The rubber cap on the solenoids goes bad and they lose contact. So far KAE is the most reliable replacement solenoid I've found.
The wire to the solenoid comes out of the bottom of the shifter above the driveshaft yoke. It often wears through and shorts out on the tailshaft housing of the tranny.
The relay is behind the center console left of the glovebox. Remove the glovebox and it will be on the left. Hella is the OE manufacturer of these relays.
smeha
Dec 29, 2014 01:16 PM
lilsilver85
Aug 29, 2014 04:07 AM
SmrkngRvng
Sep 1, 2013 08:27 AM
92slugwagon
Mar 6, 2011 07:20 PM
mrchuck85
Feb 28, 2007 09:08 PM
