1999 S70 tran coolant lines into radiator
Old Jan 17, 2011 | 11:45 AM
qvolv's Avatar
Default 1999 S70 tran coolant lines into radiator
How do you disconnect the transmission coolant lines into the radiator? Appears to be some sort of connection with o-rings? Trying to replace the radiator...and the replacement radiators which I have seen in the auto parts stores have screw-in fittings.
Old Jan 17, 2011 | 04:47 PM
Step 8 here: http://www.atthetipwebs.com/technolo...T_oil_line.htm
You may have to unscrew the line nipples from the old radiator and install them in the new radiator.
ffmeltdown
Jan 17, 2012 05:54 PM
rezology
Jun 13, 2010 10:42 PM
sgzenus
Mar 6, 2008 10:54 AM
