1999 volvo S70
Old Nov 27, 2007 | 07:21 AM
agriffis24's Avatar
Default 1999 volvo S70
I have recently purchased a 1999 S70. thinking wow great car. I have had the car 3 weeks, from the start I have had all the symptoms of the faulty ETM. I called volvo after finding the recall info. The ETM was replaced the software upgrade already done, I am having issues and the ETS light came on. I drove straight to the dealer who can find no problem and the lights are all off. This is of course my luck, I do have one question.
The ETM was replaced but with what? The same faulty module? I have seen posts where people have had to replace them up to 3 times?! Was all that work covered by the 10 year warranty? I will be holding my breath everytime I get into this car with my child.
Thanks in advance for any advice.
Old Nov 27, 2007 | 09:27 AM
S70driver's Avatar
Default RE: 1999 volvo S70
It should be covered. If not your in for a lot of money.
Old Nov 27, 2007 | 10:00 AM
jks2's Avatar
My understanding is that the ETM is not replaced. It is cleaned and the computer is remapped to make it less sensitive to possible carbon build up.
Old Nov 29, 2007 | 06:05 PM
JPN's Avatar
JPN
Welcome to the forum, I hope you find it helpful.
http://automallusa.net/1999/volvo/s70/recalls.html
Recalls must be fixed at the dealer at no charge to the customers, regardless of model year.
Good luck to you, keep us posted on the result if you would.
JPN
Old Jan 2, 2008 | 04:25 PM
ROBG's Avatar
Dealer "should" correct problem. Some dealers are just wiping
throttle body and down loading new softwear. If the light is
coming on and car is running poorly,the car needs to be
repaired. If the cause is the throttle valve body,dealer needs
to replace it and load new softwear at no charge to you.
I hope this helps.
Rob
volvos70owner
Jul 9, 2012 09:53 PM
rezology
Jun 13, 2010 10:42 PM
7antera
Jun 2, 2008 08:00 AM
S70driver
Jul 8, 2006 06:11 PM
Tony_S70_99
Jul 21, 2005 11:13 PM
