WILL 16" RIMS FROM A MAXIMA FIT MY 99 V70?
Old Jan 2, 2008 | 02:31 PM
scubblicious's Avatar
Default WILL 16" RIMS FROM A MAXIMA FIT MY 99 V70?
My car has 15" volvo 5 spoke alloy rims but i found some snows off a maxima that are 16" Maxima.Size 215/55R16 .Rims are 5 bolt, 7 inches wide
any of you guys know if they'll fit?
as always thanks,
Old Jan 2, 2008 | 02:56 PM
S70driver's Avatar
Default RE: WILL 16" RIMS FROM A MAXIMA FIT MY 99 V70?
Well you have a bolt pattern of 5x108mm, if those rims you want have the same bolt pattern then yes they will fit.
Old Jan 2, 2008 | 07:39 PM
7 inches is 177.7 MM so should i assume they wont fit ? i am mad new at swapping rims on a volvo.
Old Jan 2, 2008 | 08:56 PM
jks2's Avatar
177.7 will definitely not fit. If you are interested in larger rims there are some on the forum for sale and there are always some on ebay for sale. You will need 5 bolt 108mm. Depending on the offset you may need spacers. If you have the Cetus wheel it is a 43mm offset. Others you would need to check. It is usually cast into the back of the wheel somewhere.
87 740 turbo wagon
Feb 20, 2014 08:50 PM
rspi
Sep 18, 2013 06:17 AM
rspi
Oct 8, 2011 10:23 AM
Jahallah
Feb 27, 2009 01:04 PM
iron_rhino
Sep 15, 2008 10:57 AM
