855 Alternator Pulley, How To Change
Old Jul 11, 2010 | 05:29 PM
bruceam's Avatar
Default 855 Alternator Pulley, How To Change
I have successfully removed the old alternator from my Volvo 855 wagon. Unfortuantely, the new alternator doesn't have an accessory belt pully on it's power shaft. If I can't change the accessory belt pulley, it doesn't do any good to install the new one. Can anyone give me an idea of the proper procedure, facilities, and tools required, to:
a) remove the pulley from my old Volvo 855 Alternator without damaging it,
and how to
b) install the undamaged pulley on my new Volvo 855 Alternator?
Help, Anyone?
Bruceam
Old Jul 11, 2010 | 05:37 PM
Bobec's Avatar
I think you need this
http://www.autozone.com/autozone/acc...er=414936_0_0_
I used it to rebuild my Power steering pump. You can rent it at autozone and get a full refund when you return it.
Old Jul 11, 2010 | 05:59 PM
You need an impact gun to remove the nut from the Alt. shaft. Then the pulley will slide right off. Then install it on the new one and tighten with the impact gun and done.
Old Jul 12, 2010 | 11:48 AM
bruceam's Avatar
Tech,
Thank you for the information. I will see if I can find someone around here with an impact wrench and the appropriate socket.
Thanks Again
bruceam
Old Jul 12, 2010 | 11:51 AM
bruceam's Avatar
Bobec
I will look into the pulley puller, but the web page you referred me to indicates that it is a Power Steering Pump puller. I have one of these, and it will not work on the this alternator. The pulley on this machine is bolted down to the shaft of the alternator. It is loosening this nut that I am having difficulty doing.
Thanks for the reference. I will see what autozone has to say about this issue.
bruceam
Old Jul 12, 2010 | 11:53 AM
bruceam's Avatar
Tech
Is there a way of locking the alternator's rotor during the loosening and tighening process. Without this, the shaft will be free to spin, and the nut will never loosen or tighten.
bruceam
Old Jul 12, 2010 | 07:28 PM
It might damage it beyond repair. Or they might not give you your core money back. Maybe see if Autozone will do it for you or rent the battery impact from them.
migbro
Jun 14, 2012 07:41 AM
elimont
Apr 29, 2012 03:02 PM
guest01
Nov 5, 2011 10:11 PM
keenv70
Apr 29, 2010 09:49 PM
