91 740 starting problems
Old Jun 26, 2010 | 04:35 PM
silvervolvo91's Avatar
Default 91 740 starting problems
Hi there, I have a 91 740 and have owned for 3 years now. Its in great condition but only has one problem. Ever since i have owned it it has had some starting problems progressively worse and worse. In the past i would just wait 10-15 min and it would start now im luck if i can even get it to start. It will most of the time or a few tries start with spraying starting fluid into the intake manifold, and once it does start it runs fine and smooth and stays running. I have replaced recently the intake fuel pump, spark plugs, wires, and distributor cap. I can hear the fuel pump working in the gas tank when I turn the ignition on. Please any ideas? this is the second 740 that has done this to me.
Old Jun 26, 2010 | 08:32 PM
I would have the fuel pressure checked. I had a 740 but did not have a start problem. Does the problem only occur with the car cold, like after it has been sitting for 4+ hours? This could be a fuel pressure regulator problem or the main fuel pump could be putting less than needed pressure on the system. My guess would be the regulator is bleeding off pressure while it sits.
Does it start easy while driving it from place to place? If you drive to the store, does it start easy when you get back in the car if it has only been sitting under an hour?
Old Jun 26, 2010 | 10:29 PM
It really just does it at at random. I can start it up for 3 days in a row without a problem, and then some days it wont start at all unless i spray ether into it and still even then it sometimes wont start. And like i said once it starts it runs great. It has stalled and died only twice though but have got it running after those times. I will look into that. Thanks I highly appreciate it.
Old Jun 26, 2010 | 11:12 PM
I think I have a fuel relay from my 740. Not sure if they are the same but you are welcome to it. Just PM me and I'll ship it to you monday.
Old Jun 26, 2010 | 11:24 PM
Are you talking bout the fuel pump relay? Cuz I kno thats good unless there is another fuel relay that i dont kno about
monolith
Apr 16, 2008 12:40 AM
penkogj
Aug 23, 2006 10:07 PM
penkogj
Jun 24, 2005 09:49 AM
VolvoLisa
Mar 22, 2005 01:48 AM
bigb1rd
Mar 1, 2005 09:59 AM
