89 740 GL starting problems
Old Aug 22, 2006 | 04:04 PM
penkogj's Avatar
Default 89 740 GL starting problems
My 740 is very hard to start. When it does start it may run at idle for several minutes but eventually stalls before getting up to oper. temp. Also when running, if I try to rev the engine it stalls immediately so I haven't been able to drive it. Items replaced on this car within the last year include entire exhaust with new oxygen sensor, RPM sensor, radio supression relay and fuel injection relay. The main fuel pump and filter were replaced 2 yrs ago. I do not smell any gas when cranking the engine and I think it may be starved for fuel. However, I can here the fuel pump operating. The Check-Engine light does not come on while the car is running and this problem started "all of a sudden" last weekend. Any help on this is appreciated.
Old Aug 22, 2006 | 09:32 PM
Default RE: 89 740 GL starting problems
After is starts and stalls try pulling codes before touching the ignition switch.
The computer might pick something up. But if you cycle the key it might not.
Could also be a Power stage.
Old Aug 23, 2006 | 10:01 AM
penkogj's Avatar
I don't know how to pull codes on this car.
Old Aug 23, 2006 | 05:19 PM
cbevis's Avatar
Oh NO! The trouble codes link isn't working! I was going to paste it in here but it says the acoulnt has been suspended?
Old Aug 23, 2006 | 10:07 PM
WOW same here.
abyjake740wg
Dec 9, 2008 01:10 PM
monolith
Apr 16, 2008 12:40 AM
penkogj
Jun 24, 2005 09:49 AM
VolvoLisa
Mar 22, 2005 01:48 AM
bigb1rd
Mar 1, 2005 09:59 AM
